Old 02-02-2009, 08:50 AM
Sandro Holzer Sandro Holzer is offline
node3d.visible(viz.OFF) Problem
Hello
I have a small problems with the node3d.visible command.
if I have 2 bodies like in the following code, when I swith off the visibility of the first body, then the second body also disapears.
Is there a workaround?
Thank you
Sandro
body1 = viz.add('body1.obj')
body2 = body1.add('body2.obj')
body1.visible(viz.OFF)
