Thread: eMagin stereo
Old 12-17-2008, 12:49 PM
If you are targeting nVidia Quadro cards, then you should use quad buffered stereo. Quad buffering maintains correct swapping, regardless of framerate. To try it out in Vizard, simply use the viz.QUAD_BUFFER with viz.go():
viz.go(viz.QUAD_BUFFER)
Make sure you enable stereo in the 3D settings tab of the nVidia control panel.
