I am constructing an osg::Geode and osg::Geometry myself. And I fill the vertex coordinates (in a osg::ref_ptr<osg::Vec3Array>) and the rest myself. During this I use the convention X_OSG = X_OpenGL, Y_OSG = -Z_OpenGL and Z_OSG = Y_OpenGL so this uses the right hand coordinate system with z up. When I write the resulting geometry to an .ive (using a 100% osg application) it is just like I expect it to be. However, when I use the same code for directly creating a vizard plug-in, it is not oriented correctly.
So I am not going from Vizard to OSG, I am going from OSG to Vizard. Have you done something to the osg lib that you provide in the Vizard30API?
Thanks a lot,
best regards, Raymond
