Old 12-02-2008, 07:42 PM
Thanks for the bug report, this will be fixed in the next release. If you need the fix sooner, then modify your vizmenu.py by replacing the setVisible function of the MenuBar class with the following code:
	def setVisible(self,visible,animate=True):
		"""Make the menu hidden or visible"""
		self.__hidden = not visible
		self.__root.clearActions()
		if self.__hidden:
			if animate:
				self.__root.runAction(vizact.moveTo(self.__inactivePos,speed=HIDING_ANIMATE_SPEED,p1=-0.5,p2=0.0))
				self.__root.translate(self.__inactivePos)
			#Clear tracked item and click state
			self.__clicked = False
			self.__trackitem(None)
			if animate:
				self.__root.runAction(vizact.goto(self.__activePos,VISIBLE_ANIMATE_SPEED))
				self.__root.translate(self.__activePos)
