The PPT system is an optical tracker, so it won't interfere with the IC2 by itself. However, if you have a lot of magnetic interference in your room, then this can cause problems with the IC2. The IC2 provides the ability to turn off its internal compass which can reduce magnetic interference, but this may cause additional drift.
