Old 12-01-2008, 10:22 PM
VizMenu still in focus after calling setVisible
Ive got this menu and when I click a button, the menu hides via setVisible. When I want to, I bring the menu back, but when I use the mouse and click the menu title to it is still in focus and does not pop out until i focus its nebore menu title.
To see issue:
Run script
Select Simulation->Next Excersize
Press spacebar
Try to select Simulation
# coding: UTF-8
import vizinfo
import vizmenu
TITLE_COLOR = (.85, .85, .85)
BGCOLOR = (0.3,0.3,.5)
TITLEBGCOLOR = (0.3,0.3,.5)
class ParameterView:
	def __init__(self, menu, parameter):
		self.parameter = parameter
		self.line = menu.add(viz.TEXT3D, '_'*15)
		self.line.color(TITLE_COLOR)
		self.label = menu.add(viz.TEXT3D, parameter.name)
#		self.slider = menu.add(viz.PROGRESS_BAR, parameter.name)
		self.slider = menu.add(viz.SLIDER)
		self.textBox = menu.add(viz.TEXTBOX)
		self.textBox.length(.5)
		self.parameterName = parameter.name
		self.sliderScaleFactor = parameter.maxValue - parameter.minValue
		self.updateViewParameterChanged()
		vizact.ontextbox(self.textBox, self.textboxChanged)
		vizact.onslider(self.slider, self.sliderChanged)
		vizact.onevent(Parameter.PARAMETER_CHANGED_EVENT, lambda e: (e.obj==self.parameter, None), self.updateViewParameterChanged)
	def setVisible(self, isVisible):
		self.line.visible(isVisible)
		self.label.visible(isVisible)
		self.slider.visible(isVisible)
		self.textBox.visible(isVisible)
	def updateViewParameterChanged(self):
		try:
			if self.parameter.value != float(self.textBox.get()):
				self.textBox.message(str(self.parameter.value))
		except ValueError:
		self.slider.set(self.parameter.value / self.sliderScaleFactor)
	def textboxChanged(self, e=None):
		if self.textBox.get() != '':
			try:
				value = float(self.textBox.get())
				self.parameter.setValue(value)
			except ValueError:
				try:
					self.textBox.message("%1.2f" % (float(e.oldText)))
				except:
					self.textBox.message('')
				viz.message('Enter only numbers')
	def sliderChanged(self, e):
		value = self.slider.get() * self.sliderScaleFactor
timeInfo = None
simParametersInfo = None
graphInfo = None
paramHistory = None
messageGroup = None
simMenu = None
def setup():
	global simParametersInfo, timeInfo, graphInfo, paramHistory, messageGroup, simMenu
#	ALPHA = .5
#	messageGroup = viz.addGroup(viz.SCREEN, pos=(.5, .80, 0), scale=[1]*3)
#	messageGroup.alpha(ALPHA)
#	background = viz.addTexQuad(messageGroup, scale=(11, 2, 0), pos=[0,0,0])
#	background.zoffset(2)
#	background.alpha(ALPHA)
#	messageGroup.t = viz.addText('asdfasdfsad', parent=messageGroup, color=viz.BLACK, pos=(-.39,.028,0), scale=[.5]*3)
#	messageGroup.t.alpha(ALPHA)
	vizmenu.MENU_FONT_SIZE = 25
	vizmenu.HIDDEN_HANGOFF_AMOUNT = 0
	vizmenu.VISIBLE_ANIMATE_SPEED = 10000
	timeInfo = vizmenu.add()
	timeInfo.setAutoHide(viz.OFF)
	simMenu = timeInfo.add('Simulation')
	timeInfo.startSimulationButton = simMenu.add(viz.BUTTON, 'Start')
	timeInfo.resetSimulationButton = simMenu.add(viz.BUTTON, 'Reset')
	timeInfo.resetSimulationButton.visible(viz.OFF)
	timeInfo.nextExercise = simMenu.add(viz.BUTTON, 'Next Exercise')
	sysMenu = timeInfo.add('System')
	timeInfo.graphOnWallCheckbox = sysMenu.add(viz.CHECKBOX, 'Draw graphs on wall')
	timeInfo.parameterHistoryWindowCheckbox = sysMenu.add(viz.CHECKBOX, 'Parameter History Table')
	timeInfo.toggleParmeterWindowsButton = sysMenu.add(viz.BUTTON, 'Toggle Parameter Windows')
	timeInfo.parameterHistoryWindowCheckbox.set(1)
	timeInfo.clearTrialHistoryButton = sysMenu.add(viz.BUTTON, 'Clear History')
	timeInfo.resetViewButton = sysMenu.add(viz.BUTTON, 'Reset View Position')
	timeInfo.showForcesButton = sysMenu.add(viz.CHECKBOX, 'Show Forces')
def setMenuVisible(isVisable):
	timeInfo.setVisible(isVisable)
	timeInfo.dirty()
	if isVisable == 0:
		simMenu.setVisible(isVisable)
		simMenu.dirty()
parameterList = []
def addParameter(param, menu):
	parameterList.append(ParameterView(menu, param))
def setParameterVisible(param, isVisible):
	for parameterView in parameterList:
		if parameterView.parameter == param:
			parameterView.setVisible(isVisible)
def addOption(name, menu):
	button = menu.add(viz.CHECKBOX, name)
	return button
def addLabel(stringy, menu):
	t = menu.add(viz.TEXT3D, '_'*15)
	t.color(TITLE_COLOR)
	t = menu.add(viz.TEXT3D, stringy)
#def setMessageVisible(isViz):
#	messageGroup.visible(isViz)
#def setMessage(stingy):
#	messageGroup.t.message(stingy)
if __name__ == '__main__':
#	viz.add('gallery.ive')
	viz.clearcolor(viz.SKYBLUE)
	setup()
	setMenuVisible(1)
	setMenuVisible(0)
	vizact.onbuttondown(timeInfo.nextExercise, setMenuVisible, 0)
	vizact.onkeydown(' ' , setMenuVisible, 1)
