Old 11-24-2008, 04:07 PM
You can tell when a pool is empty by the viz.ACTION_EMPTY_EVENT or you could listen for the viz.ACTION_END_EVENT to see if a particular action has ended.
There is no animation callback event. You could manually set up a timer to expire when the animation path is done.
The current version does not accept a list for the vizact.walkTo command. Farshizzo, are there any plans for this?
