Hi Eliot,
The new avatars have a speak command similar to the old loadspeech command. This is available in the latest version. However, it doesn't work with the default heads that come with the avatar. You will need to create your own head that contains a morph target for opening the mouth. The next version of Vizard, which will be released in a few weeks, will have a sample that shows how to do this.
We recently created a plugin that allows a user to record audio from a microphone to a wav file. However, it doesn't give the user real time access to the microphone data. I will try to add this feature before the next release.
