Old 11-19-2008, 03:42 PM
checkButton should be getting called. try
def checkButton():
	print "in checkButton"
vizact.ontimer(0,checkButton)
this following line has incorrect syntax and you don't need it here for calling checkButton since you are using vizact.ontimer
starttimer(0,.001,FOREVER)
if you were using a callback with it it would be
viz.starttimer(0,0,viz.FOREVER)
one other thing is that your timer will not run every .001 seconds. It will only get called as fast as your framerate. If you use 0 for the rate the timer will be called every frame.
