Old 11-19-2008, 12:04 PM
is this what you mean. You can only click on the avatar when the dropdown is set to ON.
viz.add('court.ive')
avatar = viz.add('vcc_male.cfg', pos = [0,0,5], euler = [180,0,0])
avatar.state(1)
click_avatar = True
list = viz.addDropList()
list.addItems(['ON','OFF'])
list.translate(.85,.95)
def dropListChanged(e):
	global click_avatar
	if e.newSel == 0:
		click_avatar = True
		click_avatar = False
vizact.onlist( list, dropListChanged )
def onMouseDown(button):
	#if you pass in a value 1 a VizIntersect object will be returned
	object = viz.pick(1)
	if object.valid and click_avatar == True:
		if object.name == 'casual32_m_highpoly.CMFX':
			print "you picked the avatar's head"
			avatar.state(2)
		elif object.name == 'casual32_m_highpoly01.CMFX':
			avatar.state(4)
			print "you picked the avatar's body"
			avatar.state(1)
			print "you picked " + object.name
viz.callback(viz.MOUSEDOWN_EVENT,onMouseDown)
