Old 11-18-2008, 07:58 AM
hosier hosier is offline
Lightwave Layers
I'm working with a graphic designer who has created a multi-layered object in Lightwave that we want to use in Vizard. We want to be able to select the individual layers so that we can translate and rotate them.
I'm thinking that he'll have to save each layer as a seperate object and then I'll load them in individually and recreate the composite object.
Does Vizard have a way of loading a composite object and then assigning each part of the object to its own variable (or assigning each part to a common array) so that I'm able to work with the individual parts?
Thanks.
