Thread
changing spacing/angles for the eye-input in the HMD
2
11-17-2008, 05:49 PM
farshizzo
I think you are referring to the IPD (Interpupilary distance). You can set the IPD when viewing in stereo by using the
viz.ipd
command. For example, if you want the eyes to be separated by 5 cm you would use the following code:
viz.ipd(0.05)
farshizzo
View Public Profile
Find all posts by farshizzo
