Old 11-03-2008, 01:01 PM
this code adds the balls to an array and initially makes them invisible.
the timer goes off every half second and calls a function that makes one ball visible each time
OriginalBall = viz.add('ball.wrl')
viz.MainView.setPosition([-2,2.5,-2])
viz.MainView.setEuler([45,0,0])
balls = []
for x in [0, 0.2, 0.4, 0.6, 0.8]: ## nested loop
	for y in [0, 0.3, 0.6, 0.9]:
		ball = OriginalBall.copy() ##use the copy() to save cpu resource
		ball.translate(2+x, 2+y, 2)
		ball.setScale(.2,.2,.2)
		ball.visible(viz.OFF)
		balls.append(ball)
number = 0
def showBall():
	global number
	balls[number].visible(viz.ON)
	number +=1
vizact.ontimer2(.5,len(balls)-1,showBall)
Is this what you wanted to do?
The next time you post code use the code tags so that the indentation is preserved
