Documentation for coding a new render node?
Hi everyone,
I am investigating how I can add a new node to Vizard. This node will be coded in OpenSceneGraph so I am now looking at the Vizard30API. I guess I need to use example code in the directory CustomNode.
Can someone please confirm this? Where can I find documentation about the Vizard30API? For instance, is indeed standard OpenSceneGraph 1.2 used, it seems so from the header files and libs...
Thanks a lot!
Raymond
