Cal3D Stereo Bug?
Hello again,
I am having a problem when I try to run Vizard in Stereo mode.
Every time I try to open a particular scene with a Cal3D model
and switch to stereo mode through a hot key, Vizard crashes.
I am using an NVIDIA Quadro FX 3500, and I just updated to the
newest version of Vizard to see if that would fix the problem.
When running outside stereo mode, the scene is fine, it is only immediately
when I switch to Stereo mode through a hotkey then I get an error box and Vizard crashes out to the editor.
Vizard appears to work just fine with other demos not using the CAL3D format.
My scene only contains a CAL3D model with
