Old 10-23-2008, 04:35 PM
You can use viz.pick() to find what object the mouse is pointing at. Here's some code that uses viz.pick and checks to see if the mouse is pointing at the avatar's head mesh, body mesh, or some other object. Depending on what is picked the avatar will change animations.
viz.add('court.ive')
avatar = viz.add('vcc_male.cfg', pos = [0,0,5], euler = [180,0,0])
avatar.state(1)
def onMouseDown(button):
	#if you pass in a value 1 a VizIntersect object will be returned
	object = viz.pick(1)
	if object.valid and object.name == 'casual32_m_highpoly.CMFX':
		print "you picked the avatar's head"
		avatar.state(2)
	elif object.valid and object.name == 'casual32_m_highpoly01.CMFX':
		avatar.state(4)
		print "you picked the avatar's body"
		avatar.state(1)
		print "you picked " + object.name
viz.callback(viz.MOUSEDOWN_EVENT,onMouseDown)
