Old 10-21-2008, 06:01 AM
Sandro Holzer Sandro Holzer is offline
Hi
Thanks for answers.
The relative transform mode is a bit a problem with my application, but I tryed to do it ABS with the transform-matrix and it looks very good.
The code is the following, and it seems to work also in my big script.
Sandro
viz.clearcolor(0.1,0.1,1)
ANCHOR_POS= (0.5,1.8005,6)
bar2 = viz.add('bar.obj',pos=ANCHOR_POS)
bar = bar2.add('bar.obj')
a = 0
b = 0
def mytimer(num):
	global a,b
	if viz.iskeydown('t'):
		a = a + 1
		move()
	if viz.iskeydown('b'):
		a = a - 1
		move()
	if viz.iskeydown('f'):
		b = b + 1
		move()
	if viz.iskeydown('h'):
		b = b - 1
		move()
def move():
	X = bar.getMatrix(viz.ABS_PARENT)
	X.setAxisAngle(1,0,0,a)
	bar.update(X)
	X = bar2.getMatrix(viz.ABS_GLOBAL)
	X.setAxisAngle(0,1,0,b)
	bar2.update(X)
viz.starttimer(0,0.02,viz.FOREVER)
