Old 10-17-2008, 06:16 PM
It depends. The call to viz.directormode(viz.DIRECTOR_FAST) simply tells Vizard to allow other Python threads to run while it is rendering. If you don't have this flag set, then the only time your Python thread will run is after 100 Python virtual instructions have been executed in the main thread (see sys.setcheckinterval in the Python docs for more info).
If your thread is only performing computations or file i/o, then I would recommend setting this flag. If your thread is modifying the Vizard scene graph, then I would NOT set this flag.
