Thread
Cal3D texture issue from Max
4
10-17-2008, 12:17 PM
farshizzo
You can use the
rotate
option to specify a quaternion offset for the avatar. If you wanted to flip the avatar around 180 degrees about the Y axis then you would add the following to the top of the cfg file:
rotate = 0 1 0 0
farshizzo
View Public Profile
Find all posts by farshizzo
