Old 10-14-2008, 04:27 PM
There are two problems with your code. First your mykeyboard function should not be inside of you handlemyhotspots function. You also need a viz.callback line. Try the following code.
Once you enter the safe zone the variable openDoor will be set to true. When you leave the safe zone openDoor is set to false. When you press a key the onKeyDown function will be called. If openDoor is true and the keypressed is 'e' you will be able to open the door.
viz.MainView.setPosition(0,1.8,-5)
SAFE = 1
UNSAFE = 2
TARGET = 3
viz.add('tut_ground.wrl')
CIRCLE_X = 0
CIRCLE_Z = 3
CIRCLE_RADIUS = 0.5
openDoor = False
def handlemyhotspots(id,x,y,z):
	global openDoor
	if id == SAFE:
		print 'inside safe zone'
		openDoor = True
		viz.clearcolor(1,1,1)
		viz.starthotspot(UNSAFE,viz.RECTANGLE_HOTSPOT_OUT,0,3,2.4,6)
	elif id == UNSAFE:
		print 'outside safe zone'
		openDoor = False
		viz.clearcolor(0,0,0)
		viz.starthotspot(SAFE,viz.RECTANGLE_HOTSPOT_IN,0,3,2.4,6)
	elif id == TARGET:
		print 'at target'
viz.callback(viz.HOTSPOT_EVENT, handlemyhotspots)
viz.starthotspot(TARGET,viz.CIRCLE_HOTSPOT_IN,CIRCLE_X,CIRCLE_Z,CIRCLE_RADIUS)
import math
viz.startlayer(viz.LINES)
viz.linewidth(3)
viz.vertexcolor(viz.RED)
viz.vertex(CIRCLE_X,0,CIRCLE_Z)
viz.vertex(CIRCLE_X,2,CIRCLE_Z)
viz.startlayer(viz.LINE_LOOP)
for a in range(0,360,10):
	x = math.sin(viz.radians(a))*CIRCLE_RADIUS
	z = math.cos(viz.radians(a))*CIRCLE_RADIUS
	viz.vertex(x+CIRCLE_X,0.1,z+CIRCLE_Z)
viz.endlayer()
def onKeyDown(key):
	if key == 'e' and openDoor == True:
		print "open the door"
