Old 10-13-2008, 04:00 PM
The latency can vary when using the PPT system. It should be somewhere between 60-80 milliseconds. The latency on the PPT side can vary between 20-30 ms. Assuming you are sending the data using VRPN, this will add another 5 ms. Then on the Vizard side you will have a 32-48 ms latency due to double buffering of the output images.
