Old 10-10-2008, 12:25 PM
red/green anaglyphic ghosting
I'm using red/green anaglyphs, and getting a small amount of ghosting (i.e., I can see the left eye's red image through the right eye's green filter). I've been told that a good correction for this is to use a background that has some red and green in it (a dark brown), so that the contrast difference between the ghost image in either eye and the background is not perceptually noticeable. However, when I change the background color, the color of the objects changes as well, as if the red and green images are partially transparent. This negates the desired perceptual effect. Is there a way to prevent or work around this additive effect with anaglyphs to reduce ghosting?
