Old 09-13-2008, 07:23 AM
mspusch mspusch is offline
It seems like you are trying to install the installer for 3DSMax 2008 (you name it in the title of your post: vizard253_max8_cal3.zip ) with
3DSMax 2009 c:\program files\autodesk\3dsmax 2009\plugin.
The installer vizard253_max8_cal3.zip is ONLY for 3DSmax8 and for Vizard 2.5xxx versions.
Please kindly use Vizard3.xx and the correct installer for installing with 3DSMax 2009.
