Old 09-12-2008, 12:39 PM
Are you sure your monitor actually supports a refresh rate of 120Hz? What monitor do you have? Vizards framerate is controlled by the vertical sync signal from the monitor, so it sounds like your monitor does not actually support 120Hz.
