Vista, Cal3d, Max 2008
Sorry to bother you with more Cal3D woes, but I'm having a problem
with it recognizing the plugin.
I'm using Vista 64-bit with a 32-bit version of max.
When I install the Cal3D .exe from WorldViz for max 2008, everything
goes fine.
When I open max it tells me:
DLL <C:\Program Files (x86)\Autodesk\3ds Max 2008\PlugIns\cal3d_max_exporter.dle> failes to initialize.
Error code: 126 - The specified module could not be found.
The OSG install from worldviz works perfectly.
But for some reason I can't seem to get the CAL3D to work.
I looked in the plugins folder and there is a cal3d_max_exporter.dle
I also looked in the main directory and there is a cal3d.dll
Any suggestions?
George L.
Rowan University
