Old 08-22-2008, 10:00 AM
Karla Karla is offline
Avatar's face blacked out
Thanks for the suggestion. It works for quad objects but not for the avatar's face.
The avatar's face becomes blacked out when the texture is applied. There seems to be a difference between applying a texture to an avatar's face and applying it to other objects. I am having a similar problem as in post
http://www.worldviz.com/forum/showthread.php?t=776
Using 'texture.wrap(viz.WRAP_S,viz.REPEAT), texture.wrap(viz.WRAP_T,viz.REPEAT),' applies the texture correctly to the avatar's face. Therefore, it is not blacked out when using 'wrap.'
How can I incorporate 'wrap' with the random texture application? An error message said "'ActionData' object has no attribute 'wrap'."
Karla
[/CODE]
#August 22nd, 2008
#Orient view to look at avatar
mv_x = 0; mv_y = 1.78; mv_z = -1.0; viz.MainView.setPosition(mv_x,mv_y,mv_z)
mv_euler_x = 180; mv_euler_y = 0; mv_euler_z = 0; viz.MainView.setEuler(mv_euler_x,mv_euler_y,mv_euler_z)
#Create avatar for displaying texture
character1 = viz.add('male.cfg'); character1.translate(0,0,-1.4572); character1.rotate(0,1,0,0); character1.state(1) #Neutral state of avatar
face1 = character1.face('M-0327.vzf')	#add a face to the avatar
eyes_center = viz.add('M-0327_eyes_Center.jpg'); face1.texture(eyes_center); eyes_center.wrap(viz.WRAP_S,viz.REPEAT); eyes_center.wrap(viz.WRAP_T,viz.REPEAT)
#TRYING TO DEFINE A SEQUENCE THAT RANDOMLY CHANGES THE TEXTURE ON THE AVATAR'S FACE
#Intention: Make a Sequence that Waits 2-6sec., Randomly changes gaze, Repeats
#Use 4 positions (Left, Right, Center, and Up) to create different Eye Contact
#List of texture filenames
files = ['M-0327_eyes_Left.jpg','M-0327_eyes_Right.jpg','M-0327_eyes_Center.jpg','M-0327_eyes_Up.jpg']
#List of texture objects
textures = [ viz.addTexture(f) for f in files ]
#Create action that randomly waits between 2-6 seconds
waitTime = vizact.waittime( vizact.randfloat(2.0,6.0) )
#Create action that randomly applies texture from list above
randomTexture = vizact.texture_node( vizact.choice(textures,vizact.RANDOM) )
#Create sequence that repeats above actions indefinitely
my_action = vizact.sequence( waitTime, randomTexture, viz.FOREVER )
#Add action to avatar
face1.addAction(my_action)
#ERROR: Avatar's face is Blacked-out; need to set texture to repeating mode
#Try setting texture to repeating mode
#files = ['M-0327_eyes_Left.jpg','M-0327_eyes_Right.jpg','M-0327_eyes_Center.jpg','M-0327_eyes_Up.jpg']
#textures = [ viz.addTexture(f) for f in files ]
#waitTime = vizact.waittime( vizact.randfloat(2.0,6.0) )
#randomTexture = vizact.texture_node( vizact.choice(textures,vizact.RANDOM) )
#my_action = vizact.sequence( waitTime, randomTexture, randomTexture.wrap(viz.WRAP_S,viz.REPEAT), randomTexture.wrap(viz.WRAP_T,viz.REPEAT), viz.FOREVER )
#face1.addAction(my_action)
#ERROR: Message says 'ActionData' object has no attribute 'wrap'
