Old 08-21-2008, 11:36 AM
This is a bug in the current version. As a workaround you can add the On-The-Fly object to a group node and apply all your material settings to the group node. Either way, you still need to specify normal vectors for your OTF objects in order for the lighting calculations to work correctly. I'm not sure if you are already doing this, but the sample code you provided above does not specify normals.
