Old 08-13-2008, 02:07 PM
I still don't understand what the problem is. What you are describing is normal for 3D stereo programs. What stereo mode are you using and is it compatible with your stereo monitor? Also, are you setting the screen distance parameter? The default is 1 meter, so if you are sitting further away than 1 meter from the monitor then you will need to modify this.
