Old 08-13-2008, 01:36 PM
I've created an exe that uses win32com and it works fine on other machines. Is the exe not working on the same machine that has Vizard installed, or are you running the exe on a different machine? If it is not working when you run it on a different machine, then are you sure you have the SAPI engine installed on that machine?
