Old 08-07-2008, 11:38 AM
The corner positions of the walls need to be in the same coordinate frame as the tracker you pass to the cave.setTracker() command. You do not need to apply any offsets to the data. If you pass an orientation tracker then vizcave will use the position and orientation of the trackers to extract the position of the left/right eyes for the stereo frustums. If you are not in stereo mode, then you will not see the effect of the modified left/right eye frustums.
