Old 08-01-2008, 11:10 AM
Here is some sample code showing how to switch between 2 different keydown callback functions. You can press the 1,2 keys to set which callback to use. Pressing spacebar will print out which callback is currently registered.
def onKeyDown1(key):
	if key == '2':
		viz.callback(viz.KEYDOWN_EVENT,onKeyDown2)
	elif key == ' ':
		print 'space pressed in callback 1'
def onKeyDown2(key):
	if key == '1':
		viz.callback(viz.KEYDOWN_EVENT,onKeyDown1)
	elif key == ' ':
		print 'space pressed in callback 2'
