Old 08-01-2008, 01:49 AM
mspusch mspusch is offline
nVidia Quadro cards work if they can do fullscreen active stereo which the better ones all do. do for example the Quadro FX 570 card should work.
viz.QUAD_BUFFER should do it, combined obviously with the correct nVidia graphics card settings which must allow software controlled active stereo.
one thing that you should always do is to have ONLY the emagin connected for the first round of testing, and a monitor only 'behind' the emagin, i.e. connected thru it's out-vga port.
if you connect a monitor in parallel (i.e. with the second output of the graphics card), then this could be a reason why it's not working.
anyways, to answer the questions, all higher-end quadro cards work in stereo.
also, the nvidia geforce 7950 cards were the last series of a 'consumer card' which reliably worked with the nvidia consumer stereo driver.
