Old 04-25-2003, 12:31 PM
Hi Andy,
I just wanted to update you on a new feature of vizard.
You can now pass arguments to a script from the command line.
For example if you wanted to specify an input and output file you would do the following:
>"C:\...\Vizard.exe" myscript.py -r -a in.dat out.dat
Then in your vizard script you would read in the arguments through the variable 'viz.args', which is a list of strings. In the example above, viz.args would be ['in.dat','out.dat']
-- farshid
