Old 07-18-2008, 12:57 PM
jalvarez jalvarez is offline
I have already played with changing the order of magnitude of the constants back and forth. and it does not really give me control. the position works just fine, but the orientation does not work even if you try to manually input it from the command line.
Is there any other things I should try? or look into?
