Old 07-17-2008, 02:18 PM
fc2008 fc2008 is offline
what does this error code mean?
Heya im getting this error, im trying to make it so when the left mouse button is pressed an event occurs,
but i Keep getting the following error:
if info.valid and info.object == female:
UnboundLocalError: local variable 'info' referenced before assignment
any thoughts? the code is below:
import vizinfo
avatar = viz.add('vcc_male.cfg')
female = viz.add('vcc_female.cfg')
viz.translate(viz.HEAD_POS,0,20,-30)
viz.lookat(0,0,0)
viz.mouse(viz.OFF)
viz.clearcolor(0.5,0.5,1)
#Add the vizinfo object with a message.
infoObject = vizinfo.add('Give me feedback!')
infoObject.visible(0)
#Give it a title.
infoObject.title('Vizinfo box')
#Add GUI elements with labels.
button = infoObject.add(viz.BUTTON, 'Push me')
slider = infoObject.add(viz.SLIDER, 'Slide me')
check = infoObject.add(viz.CHECKBOX, 'Check me')
#Adjust the parameters of one of the GUI elements.
slider.vertical()
def mouse(button):
			info = viz.pick(1)
			if info.valid and info.object == ground:
				walk = vizact.walkTo([info.point[0],0,info.point[2]])
				avatar.runAction(walk)
				infoObject.visible(1)
viz.callback(viz.MOUSEDOWN_EVENT,mouse)
thankyou for your time
