Old 07-10-2008, 01:05 AM
dan12345 dan12345 is offline
another small problem with hebrew
when using the code written before - it reverses the order of the letters ( which can also be seen in the jpg you attached )
i tried fixing this using method such as
aa = array.array('c', chars)
aa.reverse()
newa = aa.tostring()
or
temp = list(string)
temp.reverse()
newString = string.join(temp, '')
but for some reason this scrambled the hebrew, and adding a text with the new strings led to strange results...
any solution?
thanks
dan
