Thread: Cal3d issue
Old 04-21-2004, 02:11 AM
Karthi Karthi is offline
Cal3d issue
Hi!
I created a charatcer in 3dsmax using character studio bi-peds and so on. The character has two animations. I have exported as a cal3d skeleton, meshes, materials and 2 animations files, i've written up the .cfg file correctly and everything.
The probelm that i am having is when i run it, I get this error:
The instruction at ________ referenced memeory at _______. The memory could not be read. Click Ok to terminate or cancel to debug.
Now i can look at each animation individuallyin the script window of Vizard. But i can't run my program. All it does is display the avatr and then i get the message. I have run my model in the cal3d_miniviewer_d3d and it seems to be working fine, there's no problem with the animations, materials or mesh. SO i can't figure out whats wrong with my model
Cheers
Karthi
