Thread: File Management
Old 07-01-2008, 09:44 AM
Uttama_vizard Uttama_vizard is offline
Yes, of course that would be the easiest solution. I have tried that out and it works. In fact, if I open and close the COM port multiple times from the same .py file, there is also no error. What, I feel that trying to access the same COM port simultaneously from different files is giving errors due to synchronization problem.
But, my application demands that I use separate .py files and one master .py file for managing the different .py files. I have found out a solution to this and now it is working fine.
What I have done is that I have tried to write in a separate .txt file some message conveying the end of execution of one .py file and then I have tried to access that .txt file, check its contents and when the condition matches, I have made my master .py file to recognize that as an event marker.
Now, it is working fine.
Thanks for your valuable suggestion.
Uttama
