Old 06-26-2008, 11:16 AM
At the beginning of the file there are a few PROTO definitions. You need to remove these and all instances of them from the rest of the file. For example, the node_info occurs many times, so you need to search the file for all occurrences and remove the definition. Once I did this the model loaded fine. Here is a screenshot of it in Vizard.
