Old 04-20-2004, 03:28 PM
Hi David,
On a side note, you could disable lighting on your object and it should be as bright as possible no matter which texture is applied. The reason your object becomes dim when you apply the transparent texture is because the MODULATE flag must be set in order for transparent textures to appear transparent. However, vizard does not automatically set the DECAL flag when you apply a non-transparent texture, that is why you must do it manually.
