Old 06-22-2008, 09:24 AM
south_bank south_bank is offline
Not so sure about the first problem, to me it sounds like it might be a program priority issue if you're running Vista, because I've had it say similar things to me before. Open up task manager, set the program priority to real-time by right clicking winviz.exe and it's more liberal with the memory it allocates. It might not do much for you but it worked slightly better after for me.
With regards to the second issue, it might just be a memory capacity issue, unless you're loading the avatars on events, for example loading them when you enter a room. If that is the case, load them at the start before the event and make them invisible to start with then visible on the event. As the geometry is pre-loaded it saves you time. Hope this helps in some way.
