Old 06-17-2008, 11:38 AM
If you want to apply your own texture to the existing ground model then you can use the following code:
tex = viz.add('mytexture.jpg')
ground.texture(tex)
Or you can create your own ground model using a 3D editor and import it directly into Vizard.
