Old 06-04-2008, 12:15 PM
Packages are indeed being dropped:
Did not receive new update from server on frame 2
Did not receive new update from server on frame 21
Did not receive new update from server on frame 40
Did not receive new update from server on frame 57
Did not receive new update from server on frame 63
Did not receive new update from server on frame 69
Did not receive new update from server on frame 103
Did not receive new update from server on frame 111
Did not receive new update from server on frame 117
Did not receive new update from server on frame 122
Did not receive new update from server on frame 140
Did not receive new update from server on frame 143
Did not receive new update from server on frame 148
Did not receive new update from server on frame 156
Did not receive new update from server on frame 175
Did not receive new update from server on frame 187
Did not receive new update from server on frame 194
Did not receive new update from server on frame 225
Did not receive new update from server on frame 233
Did not receive new update from server on frame 247
Did not receive new update from server on frame 260
Did not receive new update from server on frame 275
MotionBuilder is able to sustain the streamrate, so that's not the problem. The motionbuilder computer connects via the dtrack listener plugin to the dtrack computer. It also has a setting of framerate and it's set on 60 Hz. Dtrack itself is also set on 60 Hz and the program receives it's data from 16 IR ARTtrack camera's. I don't know if you have enough technical specifications now, so please let me know what else you have to know.
Yours, Frank
