Old 04-14-2004, 10:35 AM
Hi Matt,
I believe the default fog color is black. Have you tried changing it to some other color? For example to change the fog color to a light gray you would do the following:
viz.fogcolor(0.7,0.7,0.7)
Do your objects that appear dark have textures on them? If they have textures try doing the following:
object.appearance(viz.DECAL)
If your objects don't have textures then disabling lighting on them should fix it. You might want to try increasing the intensity of the head light:
headlight = viz.get(viz.HEAD_LIGHT)
headlight.intensity(2)
Let me know if you are still experiencing this problem and I'll try to take a look at the model.
