Old 05-30-2008, 01:14 PM
Farshizzo: thank you very much for the sample code! It works perfectly. I tried to do the same while using the live characters plugin and for some reason it didn't work then. I guess linking the box directly to the same tracker that also animated the avatar (so the same tracker was linked to a bone using MotionBuilder and to a box) could have been the problem. I will test this solution on monday and I will let you know if I still encounter some problems or if my problems are solved (during the weekends I don't have access to the live characters plugin).
