I've never used RenderMonkey, so I'm not familiar with how it works. Does it output a GLSL shader, or does it have its own format which specifies all the passes and shaders? You can definitely perform multi-pass rendering with Vizard. And Vizard supports GLSL, so technically this should be possible. What exactly do you need help with?
