Old 05-28-2008, 12:43 AM
From what you described it seems like you just need to disable dynamics on both objects. This will remove the affect of gravity. If you are manually checking for collisions using the viz.phys.intersectNode command, then move the hand to its previous position when it intersects with the object. Let me know if I misunderstood your question.
