You don't need to go fullscreen, I just want to make sure the graphics window displays the correct image. So when you replace the crosshair texture with your own pattern, the pattern doesn't fill up the entire graphics window? Have you tried reducing the size of your pattern texture to 1024x1024? Your card might not support larger textures. Other than that, I don't know what else could be wrong with your system.
