the nuvision glasses work with an IR emitter.
the emitter has a special plug (VGA break out cable) that needs to be connected to the VGA signal output that feeds the Infocus DetphQ projector.
the IT emitter needs to be placed on you projection screen or on the ceiling, so the nuvison shutterglasses 'see' the emitter when people are looking at the screen.
if it's setup like this and the Vizard image is flickering (i.e. showing left/right eye with active stereo) then the glasses will work and you will see 60Hz stereo (if the projector is run with 120Hz).
hope that helps!
