Old 05-19-2008, 02:52 AM
kliment kliment is offline
I am having the same issue and a related one. I am using 3dMeNow version 2, and exporting to either OBJ or WRL (I've tried both, converting the WRL in 3dsmax per the tutorial). The major problem is that I am unable to create morphs in most cases. PeopleMaker consistently compains that there is a different number of vertices in each image. I am not sure if this is related to the bug we are encountering in 3dMeNow where asking it to export a neutral face exports a face with all the morphs superimposed on it. Thus I have been trying to export a face with morphs disabled and then another with morphs enabled. I convert them to VRML97 in 3dsmax, they look fine there, they have the same number of vertices. Once imported into PeopleMaker, they look fine (after flipping polygon order), I save them in the PeopleMaker format and then try to generate a morph. However, the mesh remains yellow no matter what I try. With 3dmenow 1 I was capable of creating some morphs, but even there most files would fail. Additionally, the heads look significantly different in PeopleMaker than they do in 3dmenow, they seem somehow squashed from the sides. How do we work around these issues?
-Kliment Yanev
